Tento zdroj a aj všetko ostatné na eshope Kaiweets prostredníctvom tohoto odkazu s 15% zľavou :
KAIWEETS.COM
KAIWEETS Wanptek APS3010H DC Power Supply
Precise Encoder Adjustment Knob: The DC power supply has a precise encoder adjustment knob. Just press the knob to switch each digit, and then turn the knob to set each digit in the range of 0-9. Unlike ordinary knobs, the coding knob of this variable dc power supply allows you to set the settings you need more accurately. 3 Groups of Internal Memories: The variable power supply has three groups of storage functions M1-M3. You can store commonly used data using the three memories storage buttons M1-M3, and recall it for use at any time without repeated input. This is beneficial to your work efficiency and is more convenient and faster.Output On/Off Button: The output on/off button makes it nice to be able to set your voltage and amps without power applied to the load. This design can prevent you from damaging the appliance because you forget to disconnect the output. Effectively improve your experiment efficiency.Short Circuit Alarm: When a short circuit occurs, the adjustable power supply will emit a buzzer alarm and stop output. At the same time protect the bench power supply and load from being damaged. In addition, the benchtop power supply has overvoltage, overcurrent, and overheat protection. Due to the special period, the shipping cost is increasing, this product will be charged an additional shipping cost of $15. Thank you for your support and understanding.
Like
0 Komentárov 0 Zdieľania 5988 Zobrazení
